steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
MikeMcr1
Nov 19, 2012Aspirant
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F]
Temp CPU 35.5 C / 95 F [Normal 0-85 C / 32-185 F]
It has always bothered me that the Pro 6 System temperature is close to the end of the normal range (65 C). In summer it went over that a few times which caused it to issue alerts. The strange thing is it doesn't seem to increase the system fan RPM as the system temperature increases, just the CPU fan. This also made me think the labels were the wrong way round.
