steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
Ney
Nov 22, 2012Aspirant
Ney wrote:
bajorgensen wrote: I can confirm the permanent 50 degrees on the Ultra 6 with .22 as well.
Even thought the atom cpu has a passive heat sink, the fan blows pretty well over the cpu.
The case is pretty well designed. I've replaces the fan with a more quiet and effective on, and disabled the PSU fan.
Very quiet and no problems!
I have the problem with the constant 50 degrees as well on a readynas ultra 6 running 4.2.22. Before the cpu was running at around 28-40 the new constant 50 makes the fans spin faster and make an annoying high pitched noise. Is there any way to roll back to 4.2.21 because this really feels like a software bug (i can turn off the unit for a while boot it 50 degrees cpu, run a lot of cpu heavy things, still 50 degrees cpu :(
Ok i figured out that a rollback was easy as pie. And CPU temperatures are now back to normal! :D So I at least can recommend people with constant 50C temperatures to roll back to 21.
