steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
MikeMcr1
Nov 23, 2012Aspirant
evan wrote: There is CPU fan in Pro6, so CPU temperature is low, I need to ask RD to check Pro 6's system temperature.
There is not CPU fan in Ultra 2/4/6 and Pro 2/4,
Thank you, it would also be interesting to learn where the sensor is located for the system temperature in the Pro 6.
