steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
jrc72
Sep 29, 2013Aspirant
Ney wrote:
Ney wrote:
bajorgensen wrote: I can confirm the permanent 50 degrees on the Ultra 6 with .22 as well.
Even thought the atom cpu has a passive heat sink, the fan blows pretty well over the cpu.
The case is pretty well designed. I've replaces the fan with a more quiet and effective on, and disabled the PSU fan.
Very quiet and no problems!
I have the problem with the constant 50 degrees as well on a readynas ultra 6 running 4.2.22. Before the cpu was running at around 28-40 the new constant 50 makes the fans spin faster and make an annoying high pitched noise. Is there any way to roll back to 4.2.21 because this really feels like a software bug (i can turn off the unit for a while boot it 50 degrees cpu, run a lot of cpu heavy things, still 50 degrees cpu :(
Ok i figured out that a rollback was easy as pie. And CPU temperatures are now back to normal! :D So I at least can recommend people with constant 50C temperatures to roll back to 21.
Ok I am also tired of my system temp sitting at 50dC and the damn fan cutting in and out constantly, even at a room temp of 16dC the fan starts and stops, which is crazy.
Am unsure to go mucking around with my NAS and Raidar. Wondering how you did the roll back. Did you simple uninstall it and reload the older version? A few simple steps for us how yu performed this would be great.
Thanks
Johnno
