steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
Sep 29, 2013Guru - Experienced User
Download the firmware you want to re-install, unzip, and install it via frontview. 4.2.21 can be found here: http://www.readynas.com/?p=6469
If you are going back too far there would be an issue, but not if you are going back to 4.2.21. What firmware are you running now?
