steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
jerryk1
Oct 18, 2013Aspirant
Another data point
CPU Temp 21C 2057 RPM
Sys Temp 56C 897 RPM
The room temp is perhaps 23C.
I hate to have to rollback to get things to cool off, but will if I have to. Does anyone know where the system temp sensor is located?
