steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
Oct 19, 2013Guru - Experienced User
I am seeing similar temps on my Pro-6 (4.2.24)
CPU Temp 25 C / 2191 RPM
SYS Temp 56 C / 932 RPM
Though the fan noise is not a problem for me, as long as the unit stays within safe temp limits I am ok.
