cmchoi
May 23, 2014Aspirant
readynas pro 6 WD40EFRX
WD40EFRX is not in the compatibility list for readynas pro 6. But WD30EFRX is. Does anyone know why 4TB is not in the list? What issues I may run into if I choose WD40EFRX? A reason I want to go w...
cmchoi
May 24, 2014Aspirant
Tony, Thanks for info.
How long have you been running RED for Pro 6?
Is there a specific firmware that you need to have for RED to run on Pro 6?
Do you know the drives are running any cooler after switch to RED?
Any noticeable read/write performance change?
Before I spend 1K+, I like to know if it will reduce any heat from the unit. I have 2 types of drives:
Disk 1 Seagate ST33000651AS 2794 GB , 45 C / 113 F , Write-cache ON OK
Disk 2 Seagate ST33000651AS 2794 GB , 47 C / 116 F , Write-cache ON OK
Disk 3 Seagate ST33000651AS 2794 GB , 44 C / 111 F , Write-cache ON OK
Disk 4 Seagate ST33000651AS 2794 GB , 46 C / 114 F , Write-cache ON OK
Disk 5 Seagate ST3000DM001-1CH166 2794 GB , 42 C / 107 F , Write-cache ON OK
Disk 6 Seagate ST3000DM001-9YN166 2794 GB , 40 C / 104 F , Write-cache ON OK
