louprestia
Jun 08, 2020Aspirant
READYNAS PRO 6 with Logitech Media Server 7.7.6
Hi, My ReadyMAS pro running Logitech Media Server Version: 7.7.6 - 1521467459 can no linger scan my whole music collection. It fails after about 3000 tracks. Can I uninstall LMS and go back to Squeez...
louprestia
Jun 09, 2020Aspirant
Thanks.
I don;t tink I'n on OS 6, here is all the information I see in the squuze window:
Operating system: Netgear RAIDiator - EN - iso-8859-1
Platform Architecture: i686-linux
Perl Version: 5.8.8 - i486-linux-gnu-thread-multi
Database Version: DBD::SQLite 1.34_01 (sqlite 3.7.7.1)
Total Players Recognized: 0
I will probably go to OS 6, maybe logitech media server will be able to scan my library?
To do this I'll neext to backup the whole RAID so that I can replace the drives under OS6 and then copy everything back.
Whå†s the most effience tway to do this? Connect another RAID to the USB port of the ReadyNAS and copy from my Mac? Or is there a way I can loginto the readyNAS so that I can do the copy from the command line there?
Thanks.
~Lou
Jun 09, 2020Guru - Experienced User
You could create backup jobs on the NAS that copy shares to the USB drive.
But since the NAS uses only USB-2, you'll find that copying over gigabit ethernet is faster. So you could also connect the USB drive to your mac and copy over the network. Drag and Drop will work, but I'd use a tool like freefilesync (or some other copy utility) instead.
The information you'd want is the firmware running on your NAS - which is in the NAS web ui.
