Vertgo
Apr 26, 2017Aspirant
Readynas pro 6
I have a readynas 6 pro that had RAIDiator-x86 4.2.27. I had it dual redundant but the motherboard or something recently died and now it does nothing if I hit the power button. If I want my data off o...
Apr 27, 2017Guru - Experienced User
If you do go with a new 52x or 62x ReadyNAS, then the procedure to offload your data is here: https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86?cid=wmt_netgear_organic
Vertgo wrote:
I have a readynas 6 pro that had RAIDiator-x86 4.2.27. I had it dual redundant but the motherboard or something recently died and now it does nothing if I hit the power button. If I want my data off of it which piece of hardware can I buy?
You might want to check the warranty status (hardware warranty is 5 years).
The power supply is a more likely failure than the system board - and the PSU can be replaced. If you search the forum, you will find quite a bit of material on that.
One possibility is to get a new NAS, and then try to repair the Pro - if you succeed you can use it for backup of the new NAS.
