sylvainp
Jan 23, 2019Aspirant
ReadyNas Pro Business Edition (6 drives) - New CPU installed and temps
Hi all, today I just installed the CPU E7600 in the system. Now just need to find some RAM (4GB) next upgrade.
I have latest BIOS and OS 6.9.5
Using the balance settings for fan
CPU fan at ...
viperhansa
Jan 24, 2019Virtuoso
Hi,
If you check the attached pic, i have more or less the same setup.
The pic is under load so it's a bit higher than normal.
Second is that i have a bit higher ambient temperature. Around 22-23 degrees celsius.
Forgot to mention that its an Q6600 that have an higher temp from start.. 105W vs 95W
Regards
// Hans
Sandshark
Jan 24, 2019Sensei
CPU temp is notoriously mis-reported, especially at lower tmperatures. It's an Intel issue, not a Netgear one. I have seen indications that the NAS may have a low temperature threshold, below which never gets reported because it's just so unrelaiable (and well below any danger point).
- StephenBJan 25, 2019Guru - Experienced User
There are posts here where Netgear said the low readings were clamped. It sounded like that might depend on the CPU family (atom processors might be treated differently from others).
