bollar
Sep 26, 2011Aspirant
ReadyNAS Pro Business Spontaneous Reboots 16779147/19770493
Submitted to the forum in case anyone has any thoughts. This ReadyNAS Pro Business is in a situation where it appears to reboot sporadically. The symptoms are as follows: 1. backup jobs origin...
bollar
Oct 30, 2012Aspirant
OOM-9 wrote: I have looked into part of the case.
It does look like you were having some disk issues, which does not help the RAID state. I am having a support agent contact you to see if we are able to get your data volume online.
Thank you for looking into it. I do appreciate it.
I know you guys are skeptical about the state of the drives I'm using, but I have been through dozens of drives on this one (really -- at least two dozen). Anyway, just got off the phone and think the resolution is the correct one -- I'll report back.
