daiji's avatar
daiji
Readynas PRO file transfer problem
Hello.
I recently purchased a used ReadyNAS Pro and started using it, but I have a question about one strange thing.
I use Readynas by starting it up when I need it and turning it off when I am done.
However, I have found that the first time I copy a file to Readynas after it starts, the transfer rate always drops to 0 bps.
Immediately after copying starts, it drops to 0bps, then about 30 seconds later, it rises to 110MB/s and the copying is completed to the end.
This phenomenon does not occur on the second and subsequent copies. (The speed is 110 MB/s from the beginning to the end.)
This occurs only once after Readynas is started.
I have confirmed the following points.
 1) Increased ReadyNAS memory to 2GB.
   → The time to drop to 0 bps increased by a few seconds, but the result is the same.
 2) PC and Readynas are directly connected by LAN cable.
   →The result is the same.
 3) The MTU of the PC was set to 1500 bytes. (The original MTU was 9000)
   -> Result is the same.
 4) Enabled the jumbo frame of PC and Readynas, and set it to 9000.
 5)I transferred from another PC to Readynas.
Readynas OS is 4.2.31, PC is Windows 10 22H2.
Please let me know if you find a solution.
  • StephenB's avatar
    Do you have disk spindown enabled on the NAS?
    BTW, you can convert your NAS to run OS-6 firmware.
    • daiji's avatar
      daiji
      Dear StephenB.
       Thank you for your reply.
      I have disabled the HDD spin down.
      By the way, I have also enabled the write cache setting.
      I do not have this problem with the Readynas 316 that I own, so it is certainly possible that the OS6 conversion is valid. (I thought about it for a bit myself.)
      However, when I converted my old Readynas Ultra6 to OS6, I had a problem where it stopped responding after 3-4 hours of continuous writing, so I have cold feet.
      • StephenB's avatar
        Did you upgrade the stock RAM from 1 GB to 2-4 GB?
ProSupport for Business
