spiderman1
Sep 07, 2016Guide
Readynas Pro Rebooting After Shutdown
Hi guys, My Pro running OS 6.5.1 continually reboots after shutdown both via UPS and direct socket modes. This started to happen when I moved my unit to another room and was putting back all the...
spiderman1
Dec 05, 2016Guide
The Seasonic Sfd 300 comes with an atx extender according to the vendor on eBay. Should I buy an extender to be safe? As to the molex connectors, I think that I will use the existing ones that came with the original PSU. I guess that is ok as well? Thanks.
- SandsharkDec 06, 2016Sensei
The eBay vendor may be adding it because he knows the typical use is for a ReadyNAS that uses it. I purchased from online retailers.
