spiderman1
Sep 07, 2016Guide
Readynas Pro Rebooting After Shutdown
Hi guys, My Pro running OS 6.5.1 continually reboots after shutdown both via UPS and direct socket modes. This started to happen when I moved my unit to another room and was putting back all the...
spiderman1
Dec 28, 2016Guide
I have now successfully replaced the PSU unit in the system fan on the Pro. Everything is working just fine. I would like to change the CPU fan, however, be cool master fan suggested as a replacement has only three connectors. If I were to change the CPU fan I've heard that the system software has no impact over fan speed at this point given that this is a three connectors CPU fan. Is this true?
Sandshark
Dec 29, 2016Sensei
I replaced one with a Delta EFC0812DB-PWM, which is 4-pin and available from eBay, Amazon, and Digikey. The speed range is similar to the stock fan and it maintains a similar CPU temperature. Evercool also makes an 80x80x15 4-pin fan, but iot's not rated for speeds below 200RPM and it produces a lower flow rate than th Delta.
I have another starting to make some noise, so expect to be doing it to another one soon.
