kped
Dec 04, 2012Aspirant
ReadyNAS Pro (RNDP4410-100NAS)
I am getting ready to upgrade my memory on my NAS unit.
I purchased the Corsair VS4GSDS800D2 4GB DDR2
My question is, how long does it take to run the memory test after install? This unit is used by 30 employees daily.
Thanks
Thanks
- ReadySECUREApprenticeShouldn't take too long to run, perhaps anywhere between 1 hour to 4 hours. It should only do 1 pass of the memory test and then you would need to reboot the unit. It will sit and do passes until the end of time (or the memory sticks)
- chirpaLuminaryIdeally, best to run during downtime (evening/weekend) to get multiple passes in.
- kpedAspirantThank you for the replies, looks like I will be working this weekend!
- kpedAspirantIf I set it to do a memory test, will it only do one test, then require attention? Or if I set it to run a memory test over night will it just continue to run the test over and over?
- chirpaLuminaryIt will run over and over, non-stop, until you stop it. The screen would display any errors found.
- kpedAspirantQuick update. I installed the new memory. Let it do a check over night. Ran 5 tests with zero errors.
Is there a way to display how much memory it is running on the LCD? - chirpaLuminaryNo, LCD won't show it. Would have to boot up and check FrontView.
