boris_hodak
Nov 21, 2015Aspirant
ReadyNAS Pro6 parts replacement
So my Pro6 died recently. Apparently the nework card bit the bullet which I am OK with, rather than having the drives fry. The problem is that I am having an issue tracking down the replacement parts...
BrianL2
Nov 22, 2015NETGEAR Employee Retired
Hi boris_hodak,
NETGEAR doesn't sell parts. I suggest that you buy a similar unit from the market or consider purchasing a new ReadyNAS system (RN31600 or RN51600).
Kind regards,
BrianL
NETGEAR Community Team
Nov 23, 2015Guru - Experienced User
You could possibly try buying a used unit for parts.
