XrayDoc88's avatar
Mar 24, 2020
ReadyNAS Question Before Purchase
I currently have a ReadyNAS 628X in my home which is working well.  Other than the RAID 5 setup, I don't have a true backup solution.  I am considering purchasing a second ReadyNAS to use as my backup to my NAS.  I'd like to place this offsite so that it is safe from theft, fires and floods.  Will the software that comes with ReadyNAS allow automatic backups across the internet to my second NAS?  I haven't really used any of the ReadyNAS software other than the PLEX server.
Also, I've noticed that quite a large amount of my NAS storage space is used up by "snapshots".  I guess those are a type of backup, but residing on the same hard disks.  Is there a way to decrease the amount of snapshots or turn them off entirely?  What do people recommend about snapshots?  Thanks!
  • StephenB's avatar
    Snapshots aren't really a backup - they are more like the "previous versions" feature of Windows 10 (and in fact they are integrated into that feature of windows).  They can be handy if you want to roll back to an older version of a file or folder.  But if the main share is corrupted, the snapshots will be corrupted too - they are incremental to the main share, and not independent copies.
    Personally I use them on most shares.  But I don't recommend the default "smart" snapshots, because they have unlimited retention, and will eventually take all your disk space.  Instead I use custom snapshots, which lets me manage the disk space.  Although the space usage depends on the amount of change, for me setting retention at 3 months results a space usage of less than 5 percent.  I find that reasonable overhead for what I get.
    Snapshots should be turned off for shares holding live databases (or shares hosting torrents).  Files that are frequently modified in place end up consuming a lot of snapshot space - and also end up fragmented in the main share.
    FWIW, I disagree with McRob1 on this feature.  Snapshots don't provide incremental backup.  I do find them useful, and in particular I like the combination of rsync backup and snapshots on the destination shares (as explained below).
    I back up to other ReadyNAS myself, though in my case the backup NAS are also on-site.  I supplement that with Crashplan for disaster recovery (Crashplan is hosted on a Windows PC that has the NAS data volume mounted as a drive letter).
    I use rsync as the backup protocol, since I do want high-availability of the backup (ReadyDR doesn't provide high availability, you need to restore the backup to a share).  I use share-by-share backup (one backup job per share).  Snapshots are enabled on the destination shares - again with 3 months retention.  I've also set the option to automatically delete files on the destination that are no longer on the source.  This combination makes the destination a strict copy of the source share, and gives me 3 months of versioning (using the snapshots).
    Both can be done remotely - as Sandshark says, a VPN is a good way to connect to the remote NAS.  You can also use port forwarding with both ReadyDR and Rsync - but in the case of rsync you should use rsync-over-ssh because normal rsync isn't encrypted.  And make sure you have a strong admin password.  You do want to make sure that port forwarding is enabled on both sites, as you likely would want to restore backups remotely (not just create them).
    FWIW, I also suggest getting a UPS for both NAS.  A lot of data loss stories begin with an unexpected power loss (or power surge).  A UPS will give you some protection against surges, and also makes sure the NAS will shut down cleanly when the UPS battery runs down.
    BTW, I also recommend not using the "private shares" feature of the NAS.  While they do have value in an enterprise setting, they can get in the way of backup (particularly restoring the private shares), and they don't work well with ReadyCloud.  If you do need to restrict access (personally I don't in my own home NAS), then I recommend setting up a public share with network access controls instead.  It's generally easier.  Then disable all file sharing protocols for "Home" in the admin web UI.
    XrayDoc88 wrote:
    Brother!  Why would they take away a nice option to backup your NAS remotely?  I guess they want you to use their paid cloud storage.
    So I looked at the backup tab and it lists "File Backup" and "ReadyDR".  I guess those two methods only work on a local network?
    Both options can work remotely (rsync being the best option for File Backup, especially over the internet).  Again, you would need to forward ports or use a VPN.  There are guides in the knowledge base articles.
    ReadyDR is linked to snapshots (basically it backs up to snapshots on the destination).  It is intended to replace Replicate.  It's not a highly available backup - meaning you can't directly get files or folders from the ReadyDR backup.  You have to restore the backup to a a share.  Rsync is highly available - you can easily access everything in the destination share.
    While many people go with ReadyDR, Rsync suits me better.  I do want to immediately cut over to a backup NAS if the main NAS were to fail.  And I do want to directly audit what is in the backup.
    FWIW, I don't think they removed Replicate to promote Vault (though perhaps that was a factor).  I think they did it to reduce the costs of ReadyCloud (since Replicate uses the same VPN, and the bandwidth through that VPN does cost Netgear money).  But that's just my guess - I have no inside information.
    XrayDoc88 wrote:
    I've never tried to use a VPN.  With Zero Tier do you basically make the remote NAS and your local NAS appear to be on the same local network?  You mentioned an old ReadyNAS app.  Is that also needed along with Zero Tier?
    The ZeroTier app is definitely needed.
    In addition to creating a virtual network for the two NAS, you should also install ZeroTier on at least one PC - which will let you administer both NAS remotely.  You can also install it on your mobile devices, and use ZeroTier for remote access (instead of ReadyCloud).
    ZeroTier can be intimidating - it has lots of functionality which most home users don't understand or need.  But you don't need to use all that stuff, and there are some guides at ZeroTier.com.  You are trusting the ZeroTier folks to keep the VPN network secure - though I know of no breaches and personally I'd be comfortable with that.
    The main risk I see here is that the ZeroTier app is old, and not supported.  It's likely that it will break at some point in the future - and if it does you'll need to switch to another solution (or hope someone updates the app).
    • XrayDoc88's avatar
      XrayDoc88
      Guide
      Thanks for all the advice and suggestions, though my head is spinning a bit.  :smileyembarrassed:
      Is rsync the same as Resilio Sync?  I don't see rsync listed on the available apps page.  Also, if I understand correctly, you turn off snapshots on your main NAS and only have them enabled on your backup NAS?
      I thought the remote backup was the most secure idea, but perhaps I should just accept using a local backup.  Granted, a fire or theft could ruin everything, but those are pretty unlikely events.  The local backup would be easier and provide faster restoration if needed.
      • StephenB's avatar
        I have snapshots enabled on both the main NAS and the backup. The snapshots are taken shortly before the nightly backup is done.
        The backup NAS is also on a power schedule, so it is turned off most of the day.  Having snapshots enabled on the main NAS makes it simpler to access the previous versions.
  • I also have a ReadyNAS 628X in my home.  I use a ReadyNAS 516 as a backup NAS.  I have created automatic backup jobs on the 516 that run once a week.  I only turn the 516 on automatically to run the backup jobs.  One job for each share. I attempted to backup remotely until my Comcast 1TB montly data limit was reached so I had to come up with a different plan.  Netgear has discontinued support for the remote backup software anyway.  I also have a Western Digital 16 TB external drive that I keep in a fire proof safe that I use for monthly backups in place of a externaly stored backups.  This is a manual process though.
    I have turned off all snapshots.  They are only good for incremental data backup anyway.  I have no need for this and they take up way to much space.  If you go to the Shares tab, and then select the share you want to change.  On the far right side of the screen there is a gear icon that you can select settings.  The snapshot settings can be found there.
    Good Luck
      XrayDoc88
      Guide
      So I guess the built in remote backup option was called ReadyNAS Replicate?  I believe it is still being supported, but only to existing users?  It probably wouldn't let me register a new account.
    • Sandshark's avatar
      Sandshark
      Sensei
      I use a VPN to perform remote backups.  Since the backup drive is at my brother's house, and I don't want to put all of his hoouse on a VPN with mine, I use ZeroTier, which is loaded to each NAS.  The ReadyNAS app available on GitHub is old, but still works; or you can install it via SSH and instructions on the ZeroTier site,  If you have the ability to set up the remote location on a VPN, then there are other solutions that work.
      Rsync over SSH is yet another option.  I don't use it myself, so can't give any hints, but here is a link to a Netgear KB article on the subject: https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-with-rsync-over-SSH
        XrayDoc88
        Guide
ProSupport for Business
