LarryBohen
Apr 16, 2019Aspirant
ReadyNAS ReadyNAS RNV2-S2 Compatible with Mac Time Machine with macOS Mojave?
My ReadyNAS is several years old and was previously used with a Windows PC.
I would like to use my NAS with my Mac desktop and Time Machine. Can do that? What software update do I need?
Apr 17, 2019Guru - Experienced User
LarryBohen wrote:
My ReadyNAS is several years old ...
If it's an RNV2-S2, then I think it was shipped by Infrant (before Netgear bought them in 2007). Does it have a Netgear label on the front?
Current firmware for your NAS is 4.1.16. What are you running?
- LarryBohenApr 17, 2019Aspirant
I don't have my ReadyNAS NV+ connected to my Mac yet.
I've got the installation CD that came with it in 2007. Should I install that and then update the firmware or can I just download and install the firmware?
- StephenBApr 17, 2019Guru - Experienced User
Ignore the installation CD.
What firmware are you running? There might be some intermediate upgrades along the way, especially if you are still running the original firmware.
I'm not running any firmware. I haven't used my ReadyNAS NV+ for many years and want to connect it to my Mac for Time Machine backups.
I've downloaded RAIDiator-4.1.16. When I unzip and double-click my Mac says it can't find an app to open it with. ????
