LarryBohen
Apr 16, 2019Aspirant
ReadyNAS ReadyNAS RNV2-S2 Compatible with Mac Time Machine with macOS Mojave?
My ReadyNAS is several years old and was previously used with a Windows PC.
I would like to use my NAS with my Mac desktop and Time Machine. Can do that? What software update do I need?
LarryBohen
Apr 17, 2019Aspirant
I don't have my ReadyNAS NV+ connected to my Mac yet.
I've got the installation CD that came with it in 2007. Should I install that and then update the firmware or can I just download and install the firmware?
Apr 17, 2019Guru - Experienced User
Ignore the installation CD.
What firmware are you running? There might be some intermediate upgrades along the way, especially if you are still running the original firmware.
- LarryBohenApr 17, 2019Aspirant
I'm not running any firmware. I haven't used my ReadyNAS NV+ for many years and want to connect it to my Mac for Time Machine backups.
I've downloaded RAIDiator-4.1.16. When I unzip and double-click my Mac says it can't find an app to open it with. ????
- StephenBApr 17, 2019Guru - Experienced User
Your NAS is running something now, and it would be helpful to know what it is. One way to tell that is to install the RAIDar app on your Mac. It should be able to locate your NAS on the network and identify the firmware. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Correct. The 4.1.16 firmware doesn't run on the Mac - it runs on the NAS. You need to upload the firmware image to the NAS via your browser ( http://nas-ip-address/admin ).
But since the NAS has been long neglected, there are potentially some barriers:
- The web server in your NAS might not be compatible with modern browsers
- If your firmware is very old, then it might be best to upgrade first to something in between whatever you are running now and 4.1.16.
