bjcool
Sep 26, 2019Aspirant
ReadyNAS RN10200 - How to transfer 4TB original data to a new 8TB hard drive?
Hi All, I've been using the ReadyNAS RN10200 for a few years & its been great. But now I'm running out of space & read that with the new firmware updates, the ReadyNAS RN10200 can have a capacity of...
- Sep 27, 2019
Click on the 8 TB drive in the center. Then you should be able to create a second jbod volume. If the "Create Volume" button won't respond, then click on "format" after you select the 8 TB drive.
That won't destroy data on the first disk.
The process is described on page 35 of the software manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
Sep 27, 2019Guru - Experienced User
What you can do is switch to flexraid, and then add the 8 TB drive as a second jbod volume. Then you can simply use both drives (having 12 TB of storage). Or you can transfer data using the Web UI backup jobs, and destroy the original 4 TB volume. After that you just remove the 4 TB drive and reformat it as you wish.
If you do transfer data, you'd need to create temporary share names for each share (and set up a backup job for each share). Then rename the shares after you destroy the original volume.
- SandsharkSep 27, 2019Sensei
FYI, the firmware update has nothing to do with expanding the drive size max. Netgear just advertises the NAS size based on the max drive size available at the time of release. Your NAS has, and has always had, the ability to use drives much larger than currently available. Of course, a 102 is limited by CPU and memory, so there is likely a reasonable limit beyond which you just wouldn't want to expand.
- bjcoolSep 27, 2019Aspirant
Hi Stephen,
I've switched to flexraid & added the 8TB. What do I do next to use the 8TB as a second jbod volume? I've attached a screenshot to show what options I have. But just wondering if i do this, will I lose the data on the 4TB hard drive?
Kind Regards,
Ben
- StephenBSep 27, 2019Guru - Experienced User
Hi Stephen,
Thanks so much for your help with this, much appreciated =)
Kind Regards,
Ben
