bjcool's avatar
bjcool
ReadyNAS RN10200 - How to transfer 4TB original data to a new 8TB hard drive?
Hi All, I've been using the ReadyNAS RN10200 for a few years & its been great. But now I'm running out of space & read that with the new firmware updates, the ReadyNAS RN10200 can have a capacity of...
  • StephenB's avatar
    Sep 27, 2019
    Click on the 8 TB drive in the center.  Then you should be able to create a second jbod volume.  If the "Create Volume" button won't respond, then click on "format" after you select the 8 TB drive.
    That won't destroy data on the first disk.
    The process is described on page 35 of the software manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
ProSupport for Business
