bjcool
Sep 27, 2019Aspirant
ReadyNAS RN10200 - How to transfer 4TB original data to a new 8TB hard drive?
Hi All, I've been using the ReadyNAS RN10200 for a few years & its been great. But now I'm running out of space & read that with the new firmware updates, the ReadyNAS RN10200 can have a capacity of...
- Sep 27, 2019
Click on the 8 TB drive in the center. Then you should be able to create a second jbod volume. If the "Create Volume" button won't respond, then click on "format" after you select the 8 TB drive.
That won't destroy data on the first disk.
The process is described on page 35 of the software manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
Sep 27, 2019Guru - Experienced User
What you can do is switch to flexraid, and then add the 8 TB drive as a second jbod volume. Then you can simply use both drives (having 12 TB of storage). Or you can transfer data using the Web UI backup jobs, and destroy the original 4 TB volume. After that you just remove the 4 TB drive and reformat it as you wish.
If you do transfer data, you'd need to create temporary share names for each share (and set up a backup job for each share). Then rename the shares after you destroy the original volume.
bjcool
Hi Stephen,
I've switched to flexraid & added the 8TB. What do I do next to use the 8TB as a second jbod volume? I've attached a screenshot to show what options I have. But just wondering if i do this, will I lose the data on the 4TB hard drive?
Kind Regards,
Ben
- StephenBSep 27, 2019Guru - Experienced User
