tiff_lee
Apr 09, 2020Tutor
Readynas RN104 dead, best option to recover data?
Hi all, so my RN104 appears to have died. When plugging in there is a brief flash of life on the LCD display and the ethernet port remains a solid green light but apart from that it is completely...
JohnCM_S
Apr 09, 2020NETGEAR Employee Retired
Hi tiff_lee,
Yes, since the RN214 and RN424 are both running OS6 as well, you may just transfer the disks from RN104 to RN214 or RN424.
You may also check this article for reference.
Sandshark
Apr 09, 2020Sensei
If you move to an Intel based NAS like the 424, any apps you have will no longer work. It is usually recommended you uninstall before the migration, but that option's obviously not open to you. So, delete and re-install them once you're up and running on the new NAS.
The 214 is ARM based, like your 104, so nothing needed there.
