justsumdad
Apr 23, 2025Aspirant
ReadyNAS RN104 fresh setup to replace Seagate NAS
hello, just a fresh user of the ReadyNAS system 🙂 I just acquired (used) a ReadyNAS 104 and stuck in four 4tb WD purple drives I had salvaged and tested good. Its taking days to sync,...
- Apr 23, 2025
justsumdad wrote:
any input on the two issues?
Sorry, I thought I'd posted that.
My RN102 has the same processor, and runs at 50C when idle. So your CPU temp is typical.
The NAS has a back up job capability that can copy directly from the Synology. Protocol include rsync (which is what I use), smb, and NFS.
Apr 23, 2025Guru - Experienced User
justsumdad
I will explore that backup more fully, it did not appear to do what I was hoping for but I may have missed something.
I have prepped the Vim3 SBC with Ubuntu and have it as a fall back, it will be another 30 ish hours before I can start the copy job anyhow...
I know I can start it now, I just don't like the idea of doing that while the sync/format is going on.
Thanx for the info on temp, makes me more comfortable 🙂
- StephenBApr 23, 2025Guru - Experienced User
You can set a backup job to copy a folder on the Seagate to a share on the ReadyNAS.
Isn't that what you want?
- justsumdadApr 24, 2025Aspirant
The backup job system seems to work but when I took a look at the final outcome, for some reason the folder that was copied over had odd permissions applied, I was not able to delete, rename, etc the content on the target via a windows PC
So I don't think this is going to do the job I need. Unless you can see what caused this?
- StephenBApr 24, 2025Guru - Experienced User
You can reset the permissions recursively in the NAS web ui.Select the destination share in the web ui, and then the settings wheel.
Note the network permissions (smb, etc) are on different screens than the file permissions. I generally recommend setting file permissions to be fully open (everyone read-write), and rely on network permissions alone if you want to restrict access.
