justsumdad
Apr 23, 2025Aspirant
ReadyNAS RN104 fresh setup to replace Seagate NAS
hello, just a fresh user of the ReadyNAS system 🙂 I just acquired (used) a ReadyNAS 104 and stuck in four 4tb WD purple drives I had salvaged and tested good. Its taking days to sync,...
- Apr 23, 2025
justsumdad wrote:
any input on the two issues?
Sorry, I thought I'd posted that.
My RN102 has the same processor, and runs at 50C when idle. So your CPU temp is typical.
The NAS has a back up job capability that can copy directly from the Synology. Protocol include rsync (which is what I use), smb, and NFS.
Apr 23, 2025Guru - Experienced User
justsumdad wrote:
All searches show the WD40PURX as CMR
It is CMR. FWIW, an early RN104 review said it took 32 hours to sync a 4x3TB array. Since the time is linear with storage 4x4TB should take 4/3 * 32 hours or about 43 hours.
So this appears to be slower than usual. Since one cause of a slow sync time is a failing disk, it is worth checking the logs I mentioned to see if anything is going wrong.
justsumdad
will the contents of the zip log be different from what i can see in the GUI?
Can you direct me a little on how to access this zip log plz?
- StephenBApr 23, 2025Guru - Experienced User
Yes.
Just click on "Download Logs" on the log page in the web ui.
- justsumdadApr 24, 2025Aspirant
