Greysquirrel
Oct 07, 2019Aspirant
Readynas rn104 loses server status on network
Hi, I recently changed my router from a tp link to a Netgear Nighthawk. Aside from a number of issues that this created, the one that remains and I'm stumped on is that my NAS will seemingly lose co...
Oct 07, 2019Guru - Experienced User
Are the devices accessing it with NFS using IP addresses or hostnames?
Does the Nighthawk have the armor security package enabled? How about parental controls?
- GreysquirrelOct 07, 2019Aspirant
Kodi accesses via NFS is address ie .64.12/tv shows/filename.
i have just tried this on a file using kodi despite my NAS currently not showing as a server on other devices. It did play the file but took a long time to 'find' it and start.
no idea how my other devices access. One is a Samsung wireless speaker app where the NAS shows as a server alongside Deezer etc. It simply isn't there.
My Samsung tv usually shows it as 'media connected' and it will be a source in the source list.it simply isn't there. If I manually choose the video player it says no device connected.
the app on my phone is a casting type app and scans the network when you start and used to say 'server 1' players - tv, amp, iphone etc and I could browse the server and choose what file to cast to each device. It simply drops off the app and it says servers 0.
i don't have parental controls or the armour security package (as far as I'm aware).
im usually quite savvy on this sort of thing but am completely stumped?!
- StephenBOct 07, 2019Guru - Experienced User
DLNA would of course use DLNA (upnp) broadcast messages.
Not sure which you want to troubleshoot first. But if you want to look at the DLNA stuff, look at the upnp settings in the router next. If upnp is on, turn it off. Otherwise, turn it on. Then reboot the network and retest.
