RJKJFrost
Nov 28, 2018Aspirant
READYNAS RN10400 Dead line of blue squares
Hi everyone.
Our ReadyNas Rn10400 seems to be dead?
When plugged into power (we have tried multiple outlets) all we can get is a line of blue squares on the display.
Pushing the power button do...
Nov 28, 2018Guru - Experienced User
If you purchased the NAS new, then it is covered by the three-year warranty. So I'd start by checking the warranty status. If you are covered, use Netgear paid support (my.netgear.com). Don't sign up for gearhead. Instead look for a link saying that you are requesting a warranty replacement.
If you aren't covered by warranty, then you could try to do a risk-buy of a new power adapter. The NAS chassis isn't repairable, so if that's the problem you'll need to replace it. The RN200 series is the current entry-level NAS - significantly faster than your RN104.
I do suggest removing the disks, and see if you get a different symptom when you power up. Label them by slot as you remove them.
RJKJFrost
So I'm trying to check the warranty status however I think the system was replaced by readynas under warranty not too long ago. My system says that I purchased it in 2014 however I'm sure it has since been replaced. I am trying to contact support to check on the warranty and I go through all of the support online stuff I need to so that I can call and then I get to the part where it's supposed to give me a number and I get a "please quote this number" screen, but it has no number, just a red box. (please see attached image). I try to call support and can't get through without a number. HOW do i get a hold of someone to check the actual warranty status please (as this is an odd case) or even to order replacement parts. So frustrated.
- bedlam1Nov 28, 2018Prodigy
Netgear do not offer replacement parts
- RJKJFrostNov 28, 2018Aspirant
Awesome, I'll stop looking for that then, thank you. So is there any way for me to contact support if I can't get the case number?
- StephenBNov 28, 2018Guru - Experienced User
Try PMing JohnCM_S and Marc_V . They should be able to look up the case number (and give you the support phone number if you need it).
If you have the phone number, you could try calling them and telling them that the website gave you a blank case number.
If you go to "my support", you should see your current NAS listed (with it's serial number). If that's not there, then perhaps you neglected to register it?
