icecoldbaseball
May 22, 2020Aspirant
ReadyNas RN2120 Corrupt Root
Am looking for help to start my NAS again. I am in the stage where I already did a hard factory reset, with the pin at the front. Even that, when I boot, I get "corrupt root" message on RAIDar. Follo...
Sandshark
May 22, 2020Sensei
Just to be clear, you did a "Factory Default", not just an "OS Re-install"? You need to do the factory default to get back to square zero (which does man you lose all data, but I assume you know that), and it does not sound like that's what you have done. If that iis what you did, one of the drives may be bad.
Another option is to remove the drives and zero them (just removing all partitions is usually sufficient) using a PC, then power on with the "fresh" drives. Since you've apparently not used the NAS for a bit, using the manufacturer's tools to test the drives while you have them out could save you some head scratching and/or heartburn later, too.
icecoldbaseball
Yes I factory Defaulted it.
- icecoldbaseballMay 22, 2020Aspirant
I can not even get in the GUI
