Leventh
Apr 30, 2020Apprentice
Readynas rn214 lag setup on vlan switch
Dear all, I have a D-Link dgs-1210-52 smart switch and like to know how can i configure my RN214 Nas Link Aggregation LACP on VLan, eg. maybe someone on this forum using this switch configured lag wi...
schumaku
May 01, 2020Guru - Experienced User
StephenB wrote:But if you just want to get the highest throughput to another device that also has a LAG (for instance another NAS), then using static LAGs for both devices and round-robin on the NAS is what you'd need. LACP is designed to limit the flow between two devices to 1 gigabit.
Uhhhhh Stephen ... LACP does by default (and on most of these Web/Smart Managed switch model lines of any vendor - which have a lot of common things under thier hoods) make use of an XOR xmit hash based on the L2 MAC. This does indeed limit the speed between the same teo MAC addresses on both ends of the LAN to the speed of one PHY link. In case of a pure GbE switch that's then the 1 Gb mentioned of course.
Managed L2+L3 switches allow the configuration of other xmit hash modes basing on MAC+IP address - so this limitation does not apply IMHO.
PS. On the other hand, I'm lost on how the vendors of Cable Modems and the WAN-aggregation capable routers overcome this limitation - e.g. NTGR does use LACP on the CM1100 - and there are just two MAC addresses involved on that local network: The Cable Modem "LAN" and the router WAN.
I disagree. For example, if you are doing a simple SMB transfer changing the xmit hash won't help. No matter what hash you pick, it's a single flow, and that hash will map the entire flow to a single interface. And even if you are doing something else on a different port simultaneously, there's still a 50-50 chance that the xmit hash will put both flows on the same interface.
Another complication is that there are two LACP lags (NAS->Switch and Switch-Client), and there is no guarantee that the Switch will use exactly the same hash as the NAS. So even if the NAS hash puts the two flows on the different links, the switch might not.
If you want to guarantee 2 gbit flows through the NAS->switch->client, then round-robin in the NAS and static LAG is the simplest way I know to do that. In the other direction it depends on how the sending client chooses to load packets onto the two interfaces.
BTW, my own switches don't allow me to set the hash with LACP. The GS728TPv2 is L2+L3, and includes routing functions. But it doesn't allow me to set the hash. Though I'm no longer using LACP, since my RN520 NAS both are connected with 10 gigabit.
