dtd41's avatar
dtd41
ReadyNAS RN214
The system can not backup files with special characters in the name. I have files with the following chars : ?"=
It is a problem with the system or the embedded linux being used.
    • dtd41's avatar
      dtd41
      rsync over a LAN. The NAS was smb mounted. the rsync summary:
      sent 59,173,408,422 bytes received 578,797 bytes 7,480,435.78 bytes/sec
      total size is 59,389,706,157 speedup is 1.00
      28,954 files. Example of files not transfered:
      .local/share/gvfs-metadata/sftp:host=mneme-86f18778.log
      .local/share/gvfs-metadata/sftp:host=thor,user=chris
      these are gnome configuration files. Anyway a backup should do all files
      • StephenB's avatar
        .local would be hidden, correct?
        Were there any files in.local that were copied?
ProSupport for Business
