DmitryS
Jun 18, 2019Aspirant
ReadyNAS RN3138 max LUN size
Hello! Could you please advise, is there any limit on LUN size on 3138? I try to expand my thick LUN, but the system tells that 8.4TB is the maximum size. Can I somehow expand my LUN beyond this valu...
Marc_V
Jun 18, 2019NETGEAR Employee Retired
Welcome to the Community!
What is the total capacity of your volume? You should be able to expand your Thick LUN as long as it's below or within 90% of the total volume. Using Thin LUN is a different one since you can over allocate the size.
Please see LUN concepts
HTH
Regards
- DmitrySJun 18, 2019Aspirant
Thanks for the reply, Marc_V
Total capacity of the volume is 10.91 TB. For example - if I try to create one more thick LUN it tells me that its max size can be about 0.8TB. But it does not allow me to expand my existing 8.4TB thick LUN. Is it somehow possible to expand?
- Marc_VJun 18, 2019NETGEAR Employee Retired
Total Capacity is 10.91TB you should atleast be able to set the LUN around 9.2TB with the 90% cap. Do you have any space consumed that is not used by the LUN?
you should be able to expand but if it's not letting there might be a condition not met or an issue that might need to be checked. Can you send me your logs through PM using Google drive?
Regards
I have some space consumed by data in SMB folders, but still there is about 950 Gb of free space - if I create new thick LUN it allows me to use up to 800+GB for it, but still it does not allow me to extend my existing LUN.
Where I can get detailed logs to provide you?
