shannond100
Nov 15, 2022Aspirant
Readynas RND2000 V1 (v2) LED sequence on boot
Hi all, I am trying to set up my old RND2000 to use as a network drive for my raspberry pi. But when it powers up, the leds blink like it is about to boot normally, but enter a continuous loop o...
Nov 15, 2022Guru - Experienced User
shannond100 wrote:
I am trying to set up my old RND2000 to use as a network drive for my raspberry pi. But when it powers up, the leds blink like it is about to boot normally, but enter a continuous loop of disk 1 blinking (once per second) 3 times then three rapid blinks of the power led, act and both hdd status'.
The LED status "decoder" is
1 – Vendor mismatch
2 – No disks detected
3 – Bad contents on root partition of disks
4 – Flash error
5 – Unsupported RAID configuration
You appear to have issue 3 - likely because you formatted the disk in Windows.
You can either remove the partitions using the Windows disk manager, or you can do a factory reset via the boot menu.
To remove any doubt here -
- If your NAS says "ReadyNAS Duo" on the front panel, then it is the original Duo (called the v1 here).
- If your NAS says "ReadyNAS Duo v2" on the front panel, then it is the second generation Duo (called the v2 here).
Ignore other labels, they are not relevant when determining the platform you own (and just add confusion).
Assuming the Duo v1, instructions on accessing the boot menu are in the hardware manual here (see page 15):
Also, keep in mind that the max disk size supported by the v1 is 2 TB.
- shannond100Nov 15, 2022Aspirant
so, I removed the partitions in disk management... still the same scenario... The nas seems unresponsive to me pressing the reset button, also..
I'll have a bit more of a play tomorrow when it's not bed time.
Thanks for you help so far.
edit: I should also add that nothing shows up in raidar for it either... only my readynas 104.
- StephenBNov 15, 2022Guru - Experienced User
Try powering up with no disks, and see if RAIDar finds the NAS (and confirm that you get the no disks LED code).
