shannond100
Nov 15, 2022Aspirant
Readynas RND2000 V1 (v2) LED sequence on boot
Hi all, I am trying to set up my old RND2000 to use as a network drive for my raspberry pi. But when it powers up, the leds blink like it is about to boot normally, but enter a continuous loop o...
shannond100
so, I removed the partitions in disk management... still the same scenario... The nas seems unresponsive to me pressing the reset button, also..
I'll have a bit more of a play tomorrow when it's not bed time.
Thanks for you help so far.
edit: I should also add that nothing shows up in raidar for it either... only my readynas 104.
Nov 15, 2022Guru - Experienced User
Try powering up with no disks, and see if RAIDar finds the NAS (and confirm that you get the no disks LED code).
