RobertA53
Sep 01, 2017Aspirant
readynas RND2210 duo V2 failed drive
hi, we had a power failure and when I turned the NAS drive back on, it booted up but disk 2 green light was flashing rapidly. RAIDar 6.3.0 could see the drive but would not open it. Status: Quota che...
Sandshark
Sep 07, 2017Sensei
What RAID configuration were the drives in? You say you bought a 1TB. I assume, then, that the old drives are 1TB or smaller. Otherwise, it's not going to work.
It sounds like you have two corrupt drives. One may be bad. Have you tried booting with "skip volume check"?
You may want to try booting with just the new drive in the unit. If it then goes through a normal install process, power down and switch the drive to the other slot. If everything is working without regard to slot, the chassis is fine. You should also test the old drives with the manufacturer's tools (and Seatools works pretty well for drives where the manufacturer has not provided one). Which of these actions you do first isn't important.
