sunday
Oct 18, 2011Follower
ReadyNAS RNDP6000 jumpers
Hi, Recently inherited a readynas and it seems that the jumpers on the board have been messed up. I would appreciate of anyone would be kind enough to send me the correct jumper positions. The u...
sphardy1
Oct 19, 2011Apprentice
sunday wrote: it seems that the jumpers on the board have been messed up.
How have you come to that conclusion? Which jumpers do you refer to? Maybe you can post a picture?
The unit powers up and displays ReadyNAS on the display and that's it. Any of the NIC don't get the link light.
If you are certain the cable and switch to which the unit is connected are functioning correctly, this would suggest a hardware fault and so contacting Netgear Support is the only option available to you
