leeway
Oct 04, 2015Aspirant
ReadyNAS RNDP600E fails to power up - how to recover
I have a fully populated ReadyNAS 6 bay P600E and it has become tempremental about restarting and now seems to have failed completely. While running it is fine but after a proper shutdown it shows n...
- Oct 04, 2015
Hopefully, the replacement supply will do the trick. Failure to reliably restart from a power off but able to continue once it does start is actually a very common power supply symptom. One of the voltages is probably a bit low, and moreso when the current inrush of powering on occurs. Unloaded testing of the voltages will not typically show this, either.
For future reference, you can use a standard ATX power supply to test if the power supply is the real problem before you purchase a replacement. You just have to run it with the supply external.
leeway
Oct 08, 2015Aspirant
Replacement power supply did the trick although a tight squeeze now. Funny how that same part number grows more connections but a shorter main 24 pin cable! Main thing is it's working. Thanks all.
