Storage-Henk
Mar 08, 2022Aspirant
Readynas RNDU2000 not accesible in Windows10-64
Greetings I have a Netgear NAS type Readynas RNDU2000. I need to use this back-up NAS again, that has not been used for a few years. Now I receive all kind of errors and cannot access files unless...
- Mar 08, 2022
As usual ... on the Windows 10 system, search "features" (works on any langauge), find something like "Windows-Features enable or disable", look for SMB 1.0/CIFS file sharing, tick SMB 1.0/CIFS Client and SMB 1.0/CIFS Server, and confirm.
Mar 08, 2022Guru - Experienced User
Storage-Henk wrote:
ERR_SSL_VERSION_OR_CIPHER_MISMATCH".
You can access with Internet Explorer, Edge in IE mode, or with an old browser (configured to block automatic updates). Firefox 94.0.2 definitely works.
Once you have access, you can install the add-on for 4.2.x firmware at rnxtras.com. That will add TLS 1.2 support to your NAS.
Though I think a better solution is convert the Ultra to run OS 6. That would require a small investment to upgrade the RAM.
- Storage-HenkMar 11, 2022Aspirant
StephenB wrote:
Storage-Henk wrote:
ERR_SSL_VERSION_OR_CIPHER_MISMATCH".You can access with Internet Explorer, Edge in IE mode, or with an old browser (configured to block automatic updates). Firefox 94.0.2 definitely works.
Thank you for your advice. I have not tried this one yet, but If I decide to keep using the NAS I might consider this.
Henk
