David_TBArch
Jul 15, 2020Aspirant
ReadyNAS RNDu4000 - Comparing Backed UP shares to current server shares
Hi, At our office we use the ReadyNAS RNDu4000 and currently its running on the firmware number 4.2.31. In the past few month we had some issues regarding faulty drives which have now since replace...
Jul 16, 2020Guru - Experienced User
If you are only looking for missing files and folders, then you could access the NAS using ssh (linux command line). You could then use something like diff -q.
David_TBArch
Jul 19, 2020Aspirant
Thanks Stephen,
We've sorted it out. Found a program called WinMerge which allows us to compare up to 3 different directories and we can copy and paste directly from the program once its done the scan.
