mrmilo
Aug 16, 2020Tutor
ReadyNAS RNDU6000 memory upgrade - won't boot
I bought the ReadNAS Ultra 6 with 3x3TB disk in 2011. Upgraded to OS6 long time ago even though it was not supported. Been running fine since! Few years ago I dropped using "apps" in favor of docker ...
mdgm
Aug 20, 2020Virtuoso
You possibly might have had to user lower case for the chip name. I think with a few models there might be some systems that used a different chip. Can't remember whether the Ultra 4 was one of those.
mrmilo
Aug 20, 2020Tutor
Hmm, sounds plausable but seeing that the update was already succesfull with the packaged tool i'm not gonna test that out :) Not going to touch that ever again!
- mdgmAug 21, 2020Virtuoso
Indeed. BIOS updates are not without risk. If for example the power failed during a BIOS update a device could be bricked.
Was just pointing out in case others came across this thread later.
