mrmilo
Aug 16, 2020Tutor
ReadyNAS RNDU6000 memory upgrade - won't boot
I bought the ReadNAS Ultra 6 with 3x3TB disk in 2011. Upgraded to OS6 long time ago even though it was not supported. Been running fine since! Few years ago I dropped using "apps" in favor of docker ...
SamirD
Aug 27, 2020Prodigy
Don't buy fake garbage ram direct from china. Those sites are scammers for anyone outside of the mainland.
I literally grabbed some old 2x2gb ddr2 desktop ram I had lying around and installed it in my ultra 6 a while back. The first set I tried didn't pass the memory test, so do the memory test before relying on it.
The units can take 8gb of ram via 2x 4gb modules as well, but those modules aren't cheap. Still, they can really breathe new life into your dockers so it may be worth it to you since it's literally just a 1 hour upgrade (and that's being really careful and super taking your time).
Hope this helps!
