SeventhMonkey
Jan 08, 2020Aspirant
ReadyNAS RR2304 Replacement Caddy Screws
Does anybody know the spec for the ReadyNAS 2305 caddy hard drive mounting screws? Here is a link to the 2304 page: https://www.netgear.com/business/products/storage/readynas/RR2304.aspx#tab-techspec...
SeventhMonkey
Fat finger above. Model is RR2304 NOT 2305. Thanks.
- SandsharkJan 08, 2020Sensei
Supermicro screws, available on Amazon, work great. Just be sure to get the ones you need (3.5" or 2.5" drive). They've worked for me for every ReadyNAS, desktop or rack mount, legacy or current. I've never had a 2304, but the 4220 uses the same caddies, and they work with them.
- SeventhMonkeyJan 09, 2020Aspirant
Thanks - Ordered and will arrive next weekish. Until then a few of my caddies are minus a few screws. I'll confirm before marking this solved, but pretty sure this is it.
