scuthber
May 01, 2020Aspirant
ReadyNAS SMB Plus and NULL NetBIOS Sessions
I have an old RN102 that's been exposed as "vulnerable" due to the IPC$ share permitting NULL sessions. I did see another similar post but it was inconclusive... The firmware is old (6.0.8) and I ga...
May 01, 2020Guru - Experienced User
Update the NAS first. Then if SMB plus isn't there, just download it from https://apps.readynas.com and install it manually
FWIW, you will get better performance if you do a factory reset after you finish the firmware upgrade, and then restore the files on the NAS from backup.
scuthber
May 04, 2020Aspirant
I'm up to 6.1.0.3 now and I just noticed a "Legacy Windows Discovery" checkbox in SMB settings. Is this anything to do with the IPC$ share?
- StephenBMay 04, 2020Guru - Experienced User
scuthber wrote:
I'm up to 6.10.3 now and I just noticed a "Legacy Windows Discovery" checkbox in SMB settings.
Windows 10 uses WS-Discovery Old versions of Windows used NetBios discovery. The checkbox tells the NAS to also advertise using the older method.
