Leventh
Jan 29, 2020Apprentice
ReadyNAS SMB plus
Hi, I could not find information about on ReadyNAS App. "SMB plus" what benefits we can get to have it? If anyone have information please share. Thx.
Jan 29, 2020Guru - Experienced User
It gives you access to some advanced settings that aren't in the main GUI. For instance, it lets you set the minimum SMB protocol to SMB 2 (or higher) - so you can disable SMB 1 access to the NAS.
Leventh
Dear StephenB,
As always, thank you for your reply & information.
