Rmorris
Aug 14, 2011Aspirant
Readynas Support Vendor
Who is recommended to offer on-going online support for a readynas. Unsure what the Netgear options are...they seem confusing and past history is Netgear seems slow to respond. Is it the same with pai...
Rmorris
Aug 16, 2011Aspirant
Thanks for the detailed reply, I did learn from your response that part of my problem is the learning curve. I used to be pretty tech savvy but have got behind and just dont have the time nor desire to be the Readynas expert, BUT I do want to make certain I am using it to its fullest like you explain, therefore I've been looking for someone to set me up and make sure I am using the system to its fullest so if (When) this happens I will be able to transition as you did.
