divisionmd
Nov 15, 2016Aspirant
ReadyNAS Ultra 2: how to recover data from RAID-1 disks?
Hello,
- I have a ReadyNas -> Netgear RNDU2120-100PES (check image below).
- It has a "blue light" - but the network port NIC seems totally dead. Not link at all. So my guess unit works w...
Nov 15, 2016Guru - Experienced User
You have an Ultra-2, not an RN102 - so your title isn't correct.
Your command sequence looks ok.
- mdgm-ntgrNov 15, 2016NETGEAR Employee Retired
Fixed the thread title.
It's advisable to check disk health and the state of the RAID array before proceeding to run the commands you mentioned.
- divisionmdNov 15, 2016Aspirant
Hello mdgm,
- Can you update me on the commands i should run to check the "helath and state of RAID array" ?
- Also note - > i have one of the disks attached to a PC - should i attach both disk?
Best regards,
Johan- divisionmdNov 15, 2016Aspirant
Hello Again,
- I know ran the commands:
# mdadm --assemble --scan
# vgscan
# vgchange -a y
# mount /dev/c/c /mntBut cant seem to mount the drive- error "unknown filesystem type 'linux_raid_member".
Note i have one of the two disks - connected to the PC.
Look at images below:
