stonemask
Mar 07, 2021Aspirant
ReadyNas Ultra 2 Plus Unable to connect
Good day to you all. I bought from a second hand store a some years ago my ReadyNas Ultra 2 Plus since I always wanted a NAS system. There were no disks or anything that came with the NAS, only ...
- Mar 08, 2021
stonemask wrote:
I have come to the conclusion that I need the setup disk for the NAS
No, that's not it.
stonemask wrote:
I look into my Router and find it´s IP address. 192.168.1.183.
I type that in chrome and use admin and netgear 1 as per manual and the only thing I see is Shares [No shares currently accessible] and Password to change the Password.
Log in as https://192.168.1.183/admin
If you leave off the admin bit, you end up redirected to https://192.168.1.183/shares. That will only let you browse shares that have http access enabled. It isn't enable by default, so you are seeing an empty share list.
You will get a security warning from chrome (and other browsers) because the NAS uses a self-signed certficate. There's no easy way to avoid that, so I just click through it when the warning pops up.
As far as RAIDar goes, that should be seeing the NAS. I am thinking that there might be internet security software running on the PC that is blocking the discovery protocol it uses.
stonemask wrote:
Running on Windows 10 Home 20H2
In order to access the shares with file explorer, you will have to enable the SMB 1 client on the PC. You do that by going into "turn windows features on or off". There are security implications - Windows will discourage you from turning it on. IMO it is safe to enable SMB 1 on a home network, but this is an area where people do disagree.
One option you have is to convert the Ultra to run OS 6 firmware - which supports SMB 3, and has a much newer linux kernel and more features. We can give you information here on how to do that. Though if you go forward, I also suggest that you upgrade the NAS stock memory from 1 GB to 2 GB.
stonemask
Mar 08, 2021Aspirant
Thanks for you help. Managed to login finally, installed the lates raidator update and now Raidar see´s the ReadyNAS.
So thanks for your help. Will now try to get it up and running and will then find some RAM to upgrade with. It currently has 1GB DDR3.
Mar 08, 2021Guru - Experienced User
The ultra 2 has only one slot. I think the only option is to upgrade it to 2 GB - and that 4 GB won't work.
- SandsharkMar 08, 2021Sensei
That is correct. The processor can support 4GB, but only as 2GB per slot. And Netgear built the board without the second slot.
