Paltoquet
May 18, 2022Aspirant
ReadyNAS Ultra 6 doesn't boot - Stuck on "ReadyNAS" prompt screen
Hello everyone I have exact same symptoms as the thread "ReadyNAS Ultra 6 doesn't boot - Stuck on ReadyNAS prompt screen" I took (and lightened) the message of this post sorry for me english ! ...
May 19, 2022Guru - Experienced User
Paltoquet wrote:
Attempted to power the NAS back on - it now just says "ReadyNAS" on the front panel, and won't do anything else. Holding down the reset switch does not bring up any boot menu. I have pulled all the disks, no change. I swapped the memory back to the original 1GB, no change.
This looks like a power supply issue - unfortunate timing, but perhaps linked to the extra load of rebuilding the RAID array. Perhaps Sandshark will confirm.
The PSU is something you can replace.
Paltoquet
May 21, 2022Aspirant
Hello StephenB...
removed all disks...same result ... the unit upgraded firmware without problem... shut down... and then no reboot
Sry for my english 🙂
