mpsharp
Aug 01, 2020Aspirant
ReadyNas Ultra 6 plus hangs after ~1 week (disks sleeping)
So I'd been encountering a problem where my NAS simply hangs with the LCD blank and non-responsive to a short press on the power button. Following another post here, I recently upgraded the memory ...
Aug 02, 2020Guru - Experienced User
Did you check for a full OS partition?
mpsharp
Aug 02, 2020Aspirant
StephenB wrote:Did you check for a full OS partition?
3.74TB free out of 13.72. Just a little less than 30% free.
- StephenBAug 02, 2020Guru - Experienced User
That's the data volume fullness. The OS partition is something else - a 4 GB partition that holds linux and the NAS configuration.
You can check it by downloading the log zip file, and then open up volume.log. Scroll down to the df -h section:
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 701M 3.0G 19% / tmpfs 1.9G 0 1.9G 0% /dev/shm ...
/dev/md0 is the OS partition.
- mpsharpAug 04, 2020Aspirant
Ahh I see. Yes, it looks fine.
root@medianas2:~# df -vh Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 722M 3.0G 20% / tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs 2.0G 3.7M 2.0G 1% /run tmpfs 987M 7.2M 980M 1% /run/lock tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup /dev/md127 14T 9.9T 3.8T 73% /data /dev/md127 14T 9.9T 3.8T 73% /apps /dev/md127 14T 9.9T 3.8T 73% /home
