Bert_AT
Nov 24, 2022Aspirant
ReadyNAS Ultra 6 stuck at "ReadyNAS" boot - no Upgrade!
Hi Community, I have the same problem as described in THIS thread, but I have not upgraded the operating system. It was still running on 4.2.31 (as far as i remember). I just did a factor...
Nov 24, 2022Guru - Experienced User
Bert_AT wrote:
I just did a factory reset from the boot menu. I then deleted all 6 installed hard drives using the raidar program. The deletion process ran overnight and was probably completed successfully - at about 40% I checked the last time and the next day the NAS was switched off.
Since then I can no longer boot the device and I can no longer get into the boot menu. Only the familiar "ReadyNAS" appears on the display.
Likely a failed power supply (which can be replaced).
Try removing the disks and powering up. See if you get a "no disks" status on the display. Likely you won't.
